TwinTurbo.NET: Nissan 300ZX forum - they can be replaced without removing the heads
Subject they can be replaced without removing the heads
Posted by aliaZ on September 08, 2008 at 11:18 PM
  This message has been viewed 155 times.
In Reply To Question about Replacing Valve.. posted by mikebonn on September 08, 2008 at 02:17 PM
Message with the proper tools
I think your shop is clueless...they severely under-quoted the job at 240 bucks.
They'll need to remove the timing belt, upper plenum and camshafts to get to the seals which is a hell of a lot more than 3 hours of labor.
If you're having problems with burning oil...valve stem seals would be the last item I would suspect on a turbo car. What are your symptoms? Are you sure this is the problem?
I replaced the valve seals on my 240sx without removing the head. I would get a puff of blue smoke after leaving a traffic light, which generally indicates valve stem seal failure.
